Crank case cancer
Four Digit
I have a basket case 86 Husky 400xc and I just opened up the motor. Found some cancer and was wondering about possible fixes for this?
New to this so all information is appreciated.
Thanks
Doug Walker
I clean damage like that with a cone point dremel to clean out corrosion. Do not touch any cleaned surface with your fingers or any other bare skin. Fill damage with JB Weld and pack and rough blend. Popsicle stick works well for mixing and application in tight areas.
Looks like a centercase. Check your clutch cover behind the water pump impellor. That is the most likely place to find that kind of damage. If you pic is of a centercase that damge under the crank happens when water gets into the engine sometimes long term from condensation in the engine
Jim, thanks for posting a response. You are correct, that is a photo of the center case. I going to make an assumption that you use the dremel to a point that you see clean material and go no deeper. Would you suggest just making an arbitrary rectangle to encompass all the corrosion and then clean out ALL the material?
One last question, what do you mean when you say "rough blend"? By the way, the clutch cover under the impeller is TOAST!
Thanks
Doug
By rough blend I mean after packing the cavity with JB Weld, use the applicator(popsicle stick) to smooth over and blend to general contour prior the the JB Weld starting to tack over.
No need to remove any more material than it takes to remove the corrosion . You can use a stainless steel wire brush to final clean. I did that repair behind the impellor . Mine was bad enough the seal counterbore was completely wiped out. I repaired it JB Weld inside and out leaving a core for the shaft to go through. I had a local machinist plane the JB Weld on the face to the level of the gasket surface. Then I had him backload the impellor shaft from the bottom so he could tram the shaft to establish the seal location.
If you are not comfortable doing it yourself, pm me
