Cylinder head 430 / 500 AC
adam6402
I see the part numbers are different but I thought I read somewhere on here that the 430 and 500 AC heads were interchangeable.
True or not?
i believe so i think fran k did this and it makes the 430 an easy kick over but would have to go 500 on 430.
Yeah, I know they are the same diameter, was really wondering if there was a difference in the machining of the cumbustion chamber/bowl that would have an impact one way or another? Specifically putting a 430 head on a 500
Unfortunately just because you can type air cooled 500 head doesn't make all of them the same. The 500 auto which would be an 1984 fits on in a somewhat different manner than an 1983 xc 500. I have used the lower compression head 500 on the 430 water cooled. It appears (with the air cooled 430 stuff I have) that so long as I don't use the auto 500 head which I think is the same across the 1984 models the same could be done though I havn't done it. If you want a little more compression on a 500 I would weld in filler and machine to suit. The volume of the dome, the difference is quite significant.
Fran
