Cylinder shoulder bolt for 85 Husky 500 xc
Four Digit
I am in need of a cylinder shoulder bolt for 1985 Husky 500xc. It's part number 16-11-190-01. It measures approximately 2-3/4 inches in length.
Anyone got a spare..!!
Four Digit
Doug Walker
so you have a 500?
it is not on your list, had 2 they are fun but sure do vibrate
what happened to your nut?
if you cant find one let me know and when I get home I will look
so you have a 500?
so you have a 500?
Yep... I went from a 400 to a 500. The cases on the original 400 turned out to be crap..!! Found a 500 and tore it down...unfortunately...I did number on one of the bolts getting it off the head.
If you have some....I will purchase.. Let Me know.
did you need the nut or the bolt?
the bolt is the same as a 400 the nut is unique to the 500
I am doing a top end job on a 1987 430XC, and when I was putting it back together, one of the cylinder studs (approx. 7.5" long) broke before reaching 29ft-lbs torque. Halls didn't have one, and I really didn't want to go with a used one, so I am having some machined. Most of the cost is in set-up at the shop, so 1pc is no more than a dozen. I'll have some extra's for sell if anyone is interested.
the importance of checking the studs can't be overstated
but undamaged good ones will work, I see some that are damaged from coolant, those are the suspect ones to me
I checked the part numbers to see if there was a problem with compatibility and it appears there may be. Your 87 shows a part number, for that stud, of 16-11-710-01. My 85 500 shows a part number of 16-11-883-03.
Further the studs for the 85 and 86 have the same part number. Something happened in 87....wonder what's the difference.
it's even weirder than that, look at the numbers harder 883-04 vs 883-03, but they use the same nut
what I don't get is there are 2 different studs used on 400, 430 and 500 in the strangest order a 430XC and a 500CR use the same and a 500XC and 430CR use a different one, try to figure that one out
my guess is a corrosion issue and they came up with a couple of different fixes, just how and where they use them makes no sense whatsoever
Four Digit
Doug Walker
found a nut it is 1 3/4" in length, is that what yours is?
