Disc brake problems and solution!
stormer254
I am riding my 86 Auto next weekend and decided to change the brake fluid, It looked like it was the original stuff! Drained and filled as per the manual no problem. But no matter what I did I could not get it to work. Lever straight back to the bars. A quick phone call to Andy at HVA in a bit of a panic for seals or a new master cylinder. Instead of selling me what I thought I needed he gave me a couple of solutions . The first was to tie the lever back to the handle bar over night and this should allow the air to rise up to the master cylinder. This did not work but the second suggestion of filling from the bleed screw using a garden spray unit (remove the weedkiller first!!) to supply the pressure to force the fluid through to the master cylinder worked a treat. Thanks Andy a simple and free solution:)
done the same on my yz front end conversion but used a syringe instead, like you said sometimes impossible to get a good result using the master cylinder.use a transparent connecting hose so you know when to stop and refill.
i have had good luck on many motorcycles using a mityvac on the bleeder screw while filling from the top..and sometime they want the ol pump and bleed trick. i have heard of filling from the bottom from street forums, heard it works great just never tried it
