Mike82CR430
Has anyone tried KX500 rings in a 1982 CR430??.
I got rings from ebay http://www.ebay.co.uk/itm/Piston-Ri...door_Power_Equipment&var=&hash=item5d35339514.
You just have to adjust the end gap to fit the bore.
I would buy them and thoughly inspect them prior to using. For the price, it is viable if every dimension matches the Mahle ring perfectly. Up, Down, Inside, & Out
