Does 2011 TE250/310 need steering damper
DavidB
Again just looking for advice as I plan to pull trigger on new TE310. Anyone have 250/310 and recomend a steering damper? I had a Scotts on my CRF450X and what a great device in CA deserts. Is the damper needed with a lighter and less powerful bike? I want to have fun and I will spend the money. Thanks guys.
I don't use one on any of my Huskys...I do use a scotts on my Yamaha.
The new bikes are not as stable as the old ones and they turn a lot better, I still do not think they need a damper and I have one sitting in a box on my shelf and don't use it on my TE
I ride tight enduros so maybe in the desert it may be a good idea to keep the bars from getting blown out of your hands on big hits.
I would not think that a damper is needed in most cases but in the desert I'd add one if possible for safety ....
Thanks guys. Good advice. You are obviously correct about the open desert and just general big hits. I'll see how it goes before I get one. Man did that Scottsdale work great. I would be pinned on my 450X in the desert and the bars were like butter. Ok maybe not always pinned but it sounds impressive. I'll report back when I get the bike. Hopefully this weekend.
i have a txc 250,2011.rode it about 10-12 rides .no damper.would not mind having one,if i had one i would use it on the bike.most of the time i dont even think about it tho so for me i dont think that item is a must have.uptite skid plate and some cycras and you should be good to go.the 310 even runs good with stock mapping.dan
Full disclosure as I manufacture and sell stabilizers...
...but any bike benefits IMHO. My TE511 is about the most stable bike have ever owned and mounted one up and noticed very nice advantages in the rocks and lack of fatigue at the end of the day. LOVE the way it makes the bike track and hold a line in the rocks. You have more energy at the end of the day as you are not death gripping the bars. Its one of those things that is not necessarily but once you own and use one you might not want to ever ride without one again.
here it is on my TE511...
Thanks. How does the Motosportz damper compare to Scotts? Also does this damper raise the bars? I am only 5'6" and will this be an issue? Would love to support dealers on the site.
I've had a damper on my last 3 bikes and can't find a good reason to not have one. I've used a GPR, Motosportz and a Scotts. They each have their pros & cons as far as dampers go.
