DRIVEN replacement gear shift
ripnriding
So doing everything I can NOT to lose my mind after purchasing a new to me, Used Husky TE 450, let the shopping and upgrading begin. Noticed play in the gear shift and through cafe husky found a comparable lever that didn't break the bank...47 bucks TO MY DOOR. Installed and looking mighty sexy, without play I may add. Good idea to make shafts out of steel and levers aluminum...sooo much easier to replace a lever :banana:
Just FYI, I've found with the stock shifter and the driven one they both losen up every ride. Put some loctite on the thread and it fixed it for good!
Thanks...it's been medium loctite'd up and yearning to be used..we just got 10 cm of snow with a nice crust of freezing rain...March is just around the corner....right?:banghead:
