Driveshaft seal leaking! 2009 TE510
flyinryanmtb
Went out to ocotillo last week and adjusted my chain, however I made a huge mistake and forgot to tighten the axle nut before riding. My bike is now leaking oil from the driveshaft/crankshaft behind the front sprocket. I pulled the front sprocket and noticed a seal is pushed forward. I looked at the technical drawings #16 and can't figure if this is the O-Ring or not part #41693. I'm thinking this is just a dust seal and the o-ring is behind it, however the drawing doesn't show a dust seal. Any help with this would be greatly appreciated! Thanks
well this was definitely a learning experience...for one the driveshaft is called a countershaft. I pulled the oil seal and found the oring. It definitely looks like a pain to get off so I will take your advice R_Little. Thanks
I guess my next question is how far do I press the new oil seal into the case? It looks like there is a lip recessed inside the case but idk if this is for the seal or not.
I think you just press it on until it is flush with the outside of the case.
I'd buy a new collar as well. Is yours grooved?
