bent70
I tried searching....thats a rabbit hole. Its a 310r
So my started got stuck awhile ago on the trail I pulled it and continued with just kickstarting. Today I finally reinstall the starter and test it....just spins. Pull the stator cover and test and the starter spins the worm, which spins the ring gear freely. Flywheel doesn't turn. Kick starter still works.
So its not the woodruff of the starter motor. whats after the flywheel....the gear oneway bearing, another woodruff to crank and or sprag issue?
I guess i need a flywheel puller to continue....maybe I can find an okie way to do that?
