ECU Reflash Question
Avejoe
I had my ECU reflashed by ZipTy (actually, PO did). I still have a gremlin somewhere. Just for giggles, I want to see if I can get the bike back to as close to stock as possible to see if I can isolate the problem.
Does the reflash write over the stock map? If not, I can just pull the jumper plug to put it back to the stock map?
Smog stuff is gone, but the oxygen sensor is still wired up.
2012 TE511
Thanks.
No, it's actually a two map flash so there's still a non jumper map 1 and a jumper activated map 2.
Yes.
No.
P.S.
In your ECU is new map set #3 (two maps included), but you can use jumper on|off, switch between two maps street|race in these map set.
