Educated me please
Pinittowinit
So I'm searching the planet for a bike. I'm a husqvarna guy for sure. Had a lot of them. My buddy has a 82 cr430 and I love it. I'm due for another dirtbike so I'm looking around for a basket case. However I don't have a clue of the differences in XC WR and CR. I want a late 70's to 82. I found alot of bikes but like I said what are the differences. Thanks and aloha
CR is a motocross with close ratio gears and no lights
WR is the Enduro with Lighting and wide ratio a lower travel type bike
XC is best of both, has MX suspenion the long travel with WR gear box and lighting.
More to it, but kinda the basic Difference.
good luck on your search.
Steve
OR's and XC's were designed for cross country racing. The fast guys didn't like the CR gear ratio's when they geared them up for high speed. They experimented with WR 1st, 2nd and 3rd gears and CR 4th, 5th and 6th gears and the OR's and later XC's were born.
Would an 81 xc transmission fit in a 81 cr motor?
Pretty much so long as you don't try and change displacement. It looks like the 81 250 is the last of an earlier design and the 430 is the first of the new design. Parts sheet quite confusing for 250 in 1981 trans sheet is cr wr and empty box. Other sheets some cr wr or, others cr wr xc in 250 coulum. Primary drive is the same that parts sheet. Sometimes the cr will have a different primary drive.
Thanks for the reply, there will be no change in displacement, i have an 81 xc main shaft, lay shaft and shift drum basically the whole transmission just want to find out if it will work, cause if not i might sell it.
Yes, but that is not all that is required. The primary gears are different between the WR/XC and the CR also. The 250 and 430 trannies are different as well. 4 possible combos for 81.
Regards,
Paul
