Engine Reassembly Question
tls25rs
So I have my SM510R motor completely apart, cases split, and slowly but surely getting all the parts to get it back together. Reading through the manual about the reassembly process I get to the point where they tell you to measure how wide the crankshaft is and how deep the two case halves are and then calculate how thick of a washer is needed on the end of the crankshaft before putting the cases back together.
The question, does anyone have a simple way of accurately making these three measurements? 1) Depth of case half one from the mating surface to the inner bearing race 2) Depth of case half two from the mating surface to the inner bearing race 3) Width of the crankshaft from the surface where one of the bearings sits to the surface where the washer is installed between the crankshaft and the other bearing.
Thanks
Joel
Depth Gage, Micrometer and Calipers. Not the Harbor freight ones but the expensive ones.
Later George
