Excessive gasoline drip TE449
skittles93
I took my TE449 for an hour spin today and when I got back home I noticed quite a bit of gasoline dripping from a tube underneath the bike. Is this normal for these bikes? If not what would cause this? Thanks!
Where exactly was it dripping from, near or just in front of the rear tire? From a small hose, if you follow the hose it should lead to a round one way valve behind the side panel, the valve may be bad or you may have just over filled the tank causing it to overflow out the hose...the valve looks like a small round inline fuel filter mine was green and white. If you took the smog stuff off it is very common to run the line back to in front of the rear tire.
The hose is threaded right in front of the rear suspension linkages. I was able to locate that black valve you mentioned, so it sound like I should just replace that guy? Thanks!
