AndrewS
I knew to look for it when I removed the bolt to avoid having to fish for it in the oil pan. It wasn't on the bolt, and it wasn't stuck to the bottom of the casing. It just wasn't there. I did, of course, fish through the oil pan a couple of times to make sure.
Is it a common washer that I can pick up? If so, does anyone have the specs on it?
Also, is there a trick to getting the spring to stay put when putting the filter cover back on? I finally managed it by slopping oil on the filter, and getting it to stick briefly, but it was a PITA.
Thanks!
Thanks!
j/k
