Flameout?
Nick McCabe
I have a 14' te310r that I did the airbox mod to but no remap. Occasionally, it will stall when starting out unless its revved fairly high. It's definitely not normal. Is this what people call "flameout" and is it something that will be resolved when I remap?
Idle seem fairly high now. Seems more like its running too lean. I'm thinking that the stock mapping does not account for all the extra air that is coming in due to the airbox mod. I know it adjusts the mixture once its revving and can use the oxygen sensor but initially it would be using default map values. So when I give it a decent amount of throttle right off idle it doesn't put enough fuel in and that causes the stall.
On mine after all the emissions junk was removed , added fmf power core , map 3 still had flame outs. Turned up idle 1/4 turn , haven't had a stall since
Thanks for the info bro. This is my first FI bike, which screw is for the idle?
I think your lean theory is correct. On the "old" 310 increasing the first CO setting on ibeat corrected the flameout.
Soon as its out of warranty I'm gonna take it in to the shop and have the remap done, hopefully that will end it. Didn't want to do it now and let them off the hook if something comes up.
On my 449 it's this gold colored screw. It turns counter clockwise to turn up the idle. This is my first FI dirt bike also . It took some time to get it running right , but it sure was worth the wait . I hated the bike when I first got it , it had the power of my 1970s 175 cc bike . Now the thing rocks and I didn't have to add a tuner . I'm very happy with it nowimage.jpg
I wish I could explain it . When I bought it the dealer removed a couple of things . I then sent the ECU to Zipty and had map 3 loaded. I put on the FMF pipe . I brought it back to dealer for first oil change and they did something with the TPS by advancing it somehow and turned up the idle . 30 years ago I used to do my own maintenance but that was when bikes were air cooled and not so electronically sophisticated
