Folding leavers?
juicypips
Hi im in the market for a set of folding levers for my wr 360 2002, has any one used a good set or are there any to avoid as they range from £30 to £200 budgets about mid way £100 can swing eitherway for the right set.
Thanks in advance:thumbsup:
Just put a set of barkbusters or hand guards...no need for folding levers.
If you must, ASV and Zeta make some damn pretty folding levers...you could just wrap plumbers tape under the perches so the mounts rotate under a crash (plus cut extra break grooves on the lever).
PS. For a WR360, l recommend an ezypull clutch lever and perch!!!
ive no problem with the clutch pull. its just the levers theyre pritty loose but that doesnt stop them bending when she goes down sideways on the bar, barkbusters.... yes ive been looking at thoes too.
the 360 had a horrid clutch untill i lubed it and put a heat reflective tube over the first foot thought it was a stupid idea routing it through the expansion chambers loop as its gets hot and melts the nylon coating... ;)
