Fork conversion
kev900sp
I need some advice. My sons 2004 TE250 has been upgraded to an Ohlins rear shock. I'd like to swap the Marzocchi 50mm forks off a 2006 or 2007 Husky. Has anyone done this? Will front wheel, brake and axle hardware from the 04 fit these forks? Is this a worthwhile upgrade?
The front wheel will work with the 50mm forks. You will probably have to switch out the steering stem on the triple clamp but is easy to do with a press. You will need the wider axle for the 50mm forks as well as the wider spacer for the front wheel. The 50mm fork uses a wider brake caliper mounting stance so you will need a different caliper as well.
Ive had both, no better imo. Both need tuning and the 50 on the 06 TC was a disaster. My suspension guy had to do them twice which ive never heard of thru myself, four sons bikes and several friends bikes.
The 45, imo has the same potential and might even be easier to get right.
PLUS- the 45's have to be less weight.
