Fork oil weight
supermotodaz
Just about to strip and rebuild the forks on my 73 450 wr and just wondered what weight oil
And quantity you guys have found works well, I,ve got a set of progressive springs I,m going
To use and some 10 weight oil what do you think ?
Supermoto
Have you tried the search bar when logged in. Click the advanced tab and select vintage left kickers and search on fork oil. Lots of good stuff out there to be read without making people type it again. Maybe you have tried this and not found comments on forks similar to those of your 73. Anyway, if you have not tried the search, I would say give it a try. Lots of good people here with a wealth of info. I have been reading about the same subject for multiple models. As you should expect, lots of variables, your weight, terrain, and your own preference, but a search should get you a good starting point. Scott
supermoto...might I suggest consolidating your posts to 1973 450 restoration?
In my 450 & my 400 rebuilds I used the folllowing:
I used "Coastal" (28 oz) 80-90 gear oil Petroleum based (NO synthetic) the kind of stuff you use in an old truck/car..
I am using (200 cc) Yamalume (yamaha) fork oil 15 wt (clymers recommends 20 wt)..
