fork seals
2wheels
probabky time i fixed my leaky forks. anyone used all balls fork seals? they any good. also are the special tools necasarry or do they just make it easier? think il invest in some seal savers at the same time!
Just replaced mine. Tools were the thing to have. I like the one that wraps around your fork and you beat the seal into place evenly. I also used the oil level gadget. No more guessing.. Have not had a warm day to ride yet. 4 degrees here today.
iv not done a set of seals before but watched. you can use the old seal to knock it into place can you not? and oul level gadget? is this for the forks? i generally measure the air gap or have done in the past.
best advice I was given..got was to go online at Rocky MTN ATV and pull up thier videos on fork seal replacement. single cartridge forks has 2 parts, but it is worth watching. After I watched it, I ordered some of the things they used and then I felt like a pro. It was so easy.
