Fork Spring Preload Spacer??
adam6402
Hey all,
I've read through various old threads about utlizing pre-load spacers. Only one thread mentioned the length of a spacer but that was in relation to cutting the springs down 3 inches or so. As it relates to stock '82 XC250 40MM forks, what is the max spacer length that could be used safely without limiting travel or causing the springs to bind internally?
Any feedback would be greatly appreciated.
Thanks,
Adam
I might suggest you look at this thread. http://www.cafehusky.com/threads/vinduros-suspension-setup-recommendations.17836/#post-155652
You generally want the bike to settle a little when you take it off a crate or stand and then settle more, quite a bit more when you sit on it without any weight on your feet. Putting air in the forks or putting much preload on the springs isn't generally in line with the way the suspention is designed.
I really doubt you would put in enouth spacer and still be able to get the top piece of the fork to screw in to have to worry about becoming spring bound. The idea of cutting the spring and replacing the cut portion of spring with spacer it to get a stiffer spring without having to locate and or buy one.
Often in the more modern stuff the motocross versions have adjustable preload fork caps which perhaps go somewhere in the 5 to 10 mm either way from center and the off road versions don't come with those fork caps.
fran
One other question for anyone that can answer.
I want to replace the lower steering head bearing only because the seal is toast. The upper and lower bearings and races are in great shape. I removed the circlip (30) pictured below thinking that would release the washer (29), but the washer wont budge and it does not look like it will slide over the bottom of the steering shaft (28) so that I can seperate the steering shaft from the lower clamp (27). Am I going about this the wrong way, whats the best way to pull that lower bearing? I also wanted to remove the shaft so that I could refinish the fork clamps.
See how you make out with the search function it has been covered a few times already. I have basically demolished the cage and rollers and ground the inner part down to very thin and then got it off. If I recall correctly (just reading on here) to press out that stem it goes out the long way but I never removed one.
