Found an '09 TE 310 575 miles, any words of wisdom to eval?
scubadds
I have narrowed my search down some, I found a TE310 a few hours away to check out.
It has 575 miles, comes with some extra goodies.
Power up done, extra tires, sprockets, bigger tank, recent valve check.
It is reported to be in perfect shape
Asking $4400
Seem like a reasonable deal?
I road a 2011, hope its not that different.
The 2011 is lighter and racier because it has a different chasis and motor. The 2009 is a nice bike but not really the same.
Check KBB.com. Pay nothing for extras. They are NOT a bagaining chit.
Pay PP retail only- or less!
Pull tank and check under it.
Pull air filter and make sure back-fire screen is there (if so equipped) and inspect boot for dirt.
Check wheels and suspension for loose etc.
Go over it with a fine tooth comb.
Verify ALL electrics are in good working order.
Check for leaks.
Pull all caps and sniff for burnt odors.
Trust no seller you cannot vouch for.
Test ride it COLD, verify all gears work (you'd be surpised how many bring a bike home w/ no top gear!)
Deduct for shot rubber, missing this etc....
Don't forget the OM!
Fair deals are easy to find, good deals are hard to find and STEAL's are just that- illegal. Buyer beware!
Good thing is it's a Husky and they are very hard to kill.
its a lot different from a 2011.i say buy it get the jd fi programmer and have your forks worked on.i bet you like it alot.dan
Thanks a ton guys. I will take all advice. Seems like a gently used well cared for bike as best I can tell ( I've called about 10 different people with various )
I'd say go sit on it,ride it,and make your judgement call then.Only you can tell if you like it regardless of the model,there's nothing like a ride in the saddle to tell you if it's you.:)
