OhioTed
I recently took possession of a very decent '83 XC175. Initial goal is to evaluate mechanical condition to repair/rebuild as necessary. When I attempted to pull the clutch cover however, found the frame rail is in the way!
Must engine be pulled for clutch access? Owners manual makes no reference to this. Says to simply "pull cover".
Please see pic below to illustrate. Note, "fresh" metal on end of kicker shaft is result of welds I had to grind off to remove kicker. Someone had welded the kicker base to the shaft - only because the base was stripped out! Fortunately, shaft splines are fine. However, I do need a kickstarter assembly - or just the base, if available. Anyone have one they wish to turn into cash?
