Front Axle - TE310
Da Prez
Just wondering what you folks use to pull the front axle out while doing a trailside wheel removal?
I bought my 2010 model and was told Husky wasn't including tools with the bikes. I have the Motosportz axle nut and wrench, but I have a small drift in my fanny pack to push the axle out.
Anybody sell something better? Any tips?
If the axle is lubed I spin the nut out to the last few threads, then push in and it will start to move the axle. From there I just put my finger in the axle and pull while getting pressure off the wheel. I guess you could either weld a handle on the axle or get a axle from another model with the pull handle.
when you reinstall it make sure it slides in fairly easy- make sure your fork tubes are aligned correctly whereas they have the same height- this makes a big difference and saves wear on your fork seals and bushings. George has some instructions for this somewhere but if you understand the above you get the gist- Really you should not need a drift or a BFH. If you do your fork tubes are not aligned or you need to grease and reassemble more often. It should just take some finesse like raisrx251 mentioned.
