430auto
I converted my 1984 WR250 over to front disk brakes. Simple enough with all the parts ready. The problem I am having is with trying to bleed the brakes and get pressure built up. Squeeze the lever with the bleeder open and close it before releasing the lever. Fluid is flowing fine, air bubbles have all come out. No pressure built up to actually make the piston squeeze the rotor. These are all used parts off a 1985 XC500. I wonder if the master cylinder needs a kit? I've bled lots of brakes before and it isn't rocket science so what else could the problem be? All the fluid was drained previous as I cleaned all the parts prior to installing them. Air bubbles do keep coming up in the master cylinder when I have the lid off and squeeze the lever.
Anyone?
Anyone?
