gas tank petcock treads strip
Yes, have done a couple. You need to tig weld it up with aluminum. File back to size and re tap.
Thread is M16 x 1.0
If you don't mind fitting a flange mounted type, simply clean up the face at the base of the tank and drill matching holes to accept new petcock, make a flange to match the new petcock but drill and tap the holes to fit a couple of m6 set screws. Loctite the screws in position and feed it in through the filler cap and poke the screws out of the bottom. The rest should be pretty self explanatory.
