Gas tank pressure
Khaaf162
Went on a ride this weekend and about 30 miles in my gas light came on. When I took the cap off and can hear the pressure releasing and i could not even put the whole 1gallon of gas i carrier with me in it. Got home and checked the vent lines all seemed good. Well thinking the one way valve for the breather must be bad. Can I replace this with any kind of one valve? If so witch way should it be on?
Those lines get dirt in them as well as the check valves. We lost a few races because of blockage on the 449s. I ran my fuel line breather to my air filter box (after the check valve) a long time ago. You can replace the check valve with other sources.
