turbo100
Hello,
I have an issue with the Gear Position Sensor on my Te250 -08.
The cable is pulled of from the sensor...
I have a few thoughts,
Is the sensor really used for anything apart from Neutral indicator lamp?
Can the sensor be removed without draining the oil?
Will I be able to solder back the cable if i remove the sensor or do I need to by a new one?
I would really appreciate any tips!
