Gear upgrade CR430
Mike82CR430
I seen a few threads on gears... The service bulletin recommends replacing the three kickstart gears ( Kicker, idler and clutch as a set) but makes no mention of the primary drive gear. Do you need to change this one as well??
The clutch gear is really two gears the little one turns the idler gear and the big one is turned by the gear on the crank. So if you keep the same number of teeth on the clutch one the crank one should be ok. Somewhere around 1985 the design of the three gears in post #1 visually changes I can't see any change in the design of the primary reduction gears though. Ideally a nice new big gear on the clutch would like a nice new smaller gear on the crank to rub against especially if they are aftermarket but probaby not necessary unless some needle bearings got loose and galled everything.
fran
Mike I've mixed and matched the gears sets for years now with no trouble. Just be aware that they actually used many different tooth-count combinations, and not all of them mesh correctly. I suspect this is the main reason Husky recommends replacing them as a set. Since we no longer have the option of just running down to the dealer and buying the set... we have to piece them together, often from different engines and different years as we can find them. If you start swapping, make sure you get a correct mesh all the way from the crank gear to the clutch gear to the small gear on the back to the idler to the kicker.
