General chain tension
Scott A. Tracy
I installed a 50T in the rear and still have stock 13T up front. Is there a general rule for chain tension you can recommend or stay with the manufactures spec.
Fhanks Scott
stock specs are accurate- I previously confirmed this by disconnecting the shock and rotating the swing arm which is the 'general rule' to check chain tension with an unknown - then measure/replicate that tension= stock specs
get some fatties to sit on it or strop the back down so the gearb box out out shaft , swing arm bolt and rear axle are ill in a straight line . make it bout right there .
Don't just set the slack up loose to be safe. Set up the slack to spec. Too loose is bad for other reasons. Regina discusses the "chain too loose" problems on their website. Using the correct slack is the best thing to do. A too-loose chain encounters a larger load spike when the chain goes from relaxed to tense when off and on the throttle.
