robertaccio
So I keep hearing bout our crappy fuels and all the oxi clean additives....
I use my machine weekly so I never had issues, until.
I washed the TE310 and broke my start the engine and heat cycle after intro-ing water to it. She sat for week, my best guess is that some water got in and made a nice "acid" brew and did a little number on a valve.
She would not start at all so I did all the usual stuff
pulled the fuel hose off the manifold-it spayed like a garden hose (plus I wanted to be sure of no water in the line)
pulled the throttle body-it sprayed
pulled the injector anyway and cleaned it.
Fuel system checks good
Electric time
waited to pull plug because I knew my connectors have not been serviced
removed and cleaned all electric connectors there was some corrosion an some, was good time to service them all.
checked all fuses
reseated all connectors, to get that contact scrape thing going.
pulled plug, great spark.
Electric checks good.
I am happy to certain degree.
Bike still no start.
Mech time
pop the top cover
valves are moving and clearance is good if not on the more loose side.
lock out comp release with a little piece of fuel line( trick)
check compression------zero-25
OK great
use zep preserve and liberally spry it into chamber and kick through, spray into intake port as well.
Let her sit for whiie after exercising the kick starter.
comp comes up to mid 30s more exercise comes up to 65
last check and its in the eighties
Put everything back together and she starts instantly.
I guess it could have happened with any fuel out there, but my mech has been seeing lots of services on all the carb and FI street bikes for this valve lap surface corrosion (that what I think it was) and injector clogs from the new clean fuels.
So that said just dont let em sit, run the engine and be sure to cycle your fuel through and keep it fresh or dump it (use it for the lawnmower maybe) and refill your tank with fresh fuel.
Any suggestions recommendation for one of the fuel additives ( I am going to run some Techron thru, I like that stuff), But more for the stability and water removal from the alcohol fuels.
Electric time
checked all fuses
Mech time
pop the top cover
OK great
