Got a ? about the 84 XC frame.
86 400 XC
The 2 parts i have circled are what i am trying to figure out.
Looks like a mounting set up or some thing, any idea for what?
Top is strap to hold down tank
bottom is upper roller but roller was ONLY used on 125's and 83 175. not on bigger models
The 83 alloy tank has a corresponding hook on it for the tank. I think they are the same frame. My 83 had 84 plastics and tank on it when I got it and they fitted perfectly.
83 and 84 rames are different. Head angle is 1.5 degrees steeper in 84 and there is a lsight change to the angle of the braces in the carb airbox area. there are also 84 watercooler frames (split down tube as WC were center exhaust) and 84 AC frames (single down tube as they are side exhasut)
If you need a strap, don't pay $30.00 bucks for one. Search ebay for battery hold down straps and get the same thing for less than $10.00.
