GPS Method Question
Clete
Never used a GPS for off-road before. I have a Garmin HCX Vista. Been toying around with a bit, and was just curious how others use theirs. This is probably a little old school already, but that's what I have. My plan was to mark the spot where I park the truck as one of the Waypoints, and then mark other locations as Waypoints throughout the day. Then use the Waypoints as a form of navigating to and from, or at least know I'm in the near vicinity to a Waypoint.
Last night I started messing with the Track function, will have to spend a little more time with that function.
Are there any preferences? Pros or Cons to either method. Any suggestions?
I have no idea of what features your GPS has. But most GPS devices can save a track while you ride. Essentially, it saves the exact location of where you are every few seconds. You can then download that and share it with others or use it as a guide on future rides. The same goes with tracks that others make.
Waypoints can be used in many ways, but conceptually they are landmarks. If you want to plan a route using waypoints, make sure you use a good number of waypoints so that you will be travel exactly where you want to go when getting to each waypoint... or at least fairly close to what you had in mind. You can be more casual and just use key waypoints as guides and ride in a more free form manner. You may wander around a bit more and spend more time getting to each way point that way, though, so be aware.
I'm no expert on GPS use or anything, but I've been using one for road trips (pavement) for several years. The same tools work for off road, but it's not likely you can auto-route a trip easily off road like you can hitting the pavement in the Sierras for example.
There are some good threads on GPS use on advrider.com. There are GPS routes for the Oregon Backcountry Discovery Route available, too at http://www.backcountrydiscoveryroutes.com/ There are also GPS routes for Washington's Backcountry Discovery Route and there should be for Utah soon.
Sounds like you are on the right path. Tracking draws a line where you go and way points are just points, you want to use them both. Also GPS can be used to find stuff or look at your ride afterward. I like downloading the GPX file off my GPS after a ride and looking at it on Google earth. I also use it for exploring via base maps and searching out areas. The more you work with them the more it all makes sense.
This site is pretty good. Sign up for a free account and use the App if you have any of the supported devices, like and iPad, iPhone or Android
http://www.backpacker.com/backpacker-magazine-apps/skills/15252
I wanted to use it to find a trail I knew existed but was not always well marked in real life. It lead to a town overlook. Looking at a good Topo map I just selected the turns as waypoints so I wouldn't get lost or make wrong turns and end up on the rabbit trails. With a little reading you can get the hang of importing waypoints into your GPS. Then it's like you have a roll map but don't have to really keep track of tenths of a mile....just matching waypoints to GPS positions.
