Just reused one on my Te250....put coppercoat spray on it.
PS to OHR ......doesn't mean it's an acceptable procedure for a high-strung Husky motor.
Are you in Connecticut? Who's charging $100?. I'm in Canada & I paid ~$40 CAD for my last one (from the local dealer) and our parts are more expensive than in the US......If it was only $25 I'd probably replace it, but it's $100. That's why I asked. We'll see how it goes.
OlderHuskyRider-
These aren't the same type of gaskets as what you're talking about. These are 'crush' gaskets. One time use only. Yes, I agree some multilayer copper gaskets etc. probably can be re-used. But that's not what these are. The torque specs are designed to 'crush' the molded crush ring in the gasket and effect a permanent seal. Once it's crushed it can't be re-crushed.
Sure, one or two guys might get lucky and happen to get just the right amount of torque on a re-used crush gasket. But what is that torque number & what are the right set of steps to get it? Get it wrong and you have a blown gasket 40 miles from nowhere & your buddy towing you home......
Well, after seeing the work involved, I'm chickening out. One exhaust valve has a bigger gap by .002 in 3000 miles, the cam chain has no stretch in 5000, plus the bike runs great. Do I really want to see inside that bad. I guess not.
Head gasket on Halls wesite $94.50
Jumpin' jiminy cricket.....my 1.2mm 450/510 HG was $24.24
