Header dent removal
ray_ray
Mini-Sponsor
Is there a known method for removing dents from these header pipes? had another BS fall over on my 08 TXC250 and this time I bent one of the pipes :(
Many 2t guys have had success with he frozen water method:
Fill the pipe with water, put expandable stoppers in each end and put it in the freezer overnite.
Pip repair
We use www.piperepair.com> PACIFIC CREST PIPE REPAIR HERE IN OREGON ,THEY A GREAT JOB AT VERY GOOD PRICE
Have done the frozen trick on a YZ header. It took 3 goes to get it out fully. Just fill the header with water about an inch above either side of the dent and place in the freezer. Just make sure the pipe is situated so that the water stays in situ. No need to plug the ends.
Love to hear if it works for you.
OK ... I'll give this water trick a try after 2days ride and report back later .... Water and a freezer are 2 things that I do have here :banana:
Pacific Crest has always done a great job for me in the past on the 2T pipes but I don't have access to them from my present location :(
That kit should work as heat is the way I have always seen a 2T pipe fixed.....U just gotta be careful when applying the pressure because this can blow the plug out the end ....
Google it up. There are lots of reports of fixing a dent by the frozen water method....no plugs necessary, just that the dent must have frozen water on it.
Cool ... I just was not sure about the metal on these new pipes but water can move any thing I guess :)
Here is my first attempt ... actually 4-5 attempts .... A little headway but not much ... I have my frid set on high now ... & I'm gonna try the freeze and thaw ~10% and re-freeze method ...
I would try with a long piece of solid wood and a hammer having the pipe sitting into a piece of soft wood with the shape of the pipe (half pipe) and try to push out the dents slowly.
That big one that is creased in the pipe needs to be bent out some for sure I think ... The wood trick might work well there ... I'll try this next and then maybe go to a shop and do the air pressure and heat trick ...
