Help finding a signal wire on '11 TC449
joints4sale
I am trying to add lights and other electrical stuff to my TC. I have a fuse block that I will be using that has a relay built in. I want to trigger the relay only when the bike is running. Since the bike has no electrical accessories from the factory, I will need to find another source. Does anyone have any idea of where I could find a signal wire that is hot only when the bike is running?
Fuel pump relay on left hand side of bike under airbox.
The spades can be removed from the connector easily and you can piggy back solder another signal to your relay in there. I wouldn't use this as the power supply to your signals. Rather use it as the signal to a relay for power to your signals.
