Help in installing front wheel at my Husqvarna 1987\1989 WR250
husqy250wr
Hi all.
I own a 87 WR250 that i renew and ride for fun.
Recently i got some parts from Husqvarna 1989 (or Cagiva WMX250 by its other name) .
I got the complete front fork including the wheel,brake,triangle and so on (you can see it on the pictures i added).
The problem is that the front axle has no spacers on it and the front wheel is been held in place by the caliper and disc only!
I guess it isn't the way it supposed to be.
If anyone has a 89 Husqvarna wr250 i'll appreciate some help and pictures of the wheel and the front axle and how to setup it all together.
By The Way, I have ---ALL--- the owner's manual of Husqvarna motorcycles between the years of 86-89 (125,250) and i send it to you free, just leave me a private message with your email .
Another thing, I also have a lot of parts, so if you looking for some thing for the 250 motorcycle in years 87-89 i might just have it .
Thank you,
Dor.
Thank you for the fast replay.
I have the same manual but i still dont understand from the drewing if the wheel is only held by the front caliper or there is a spacer there, that keep the wheel from not moving left and right on the axle.
Yes but still didn't find my answer.
Back then the details on manual's weren't so great :)
i'll take some pictures of the fork and the axle when i get back from the office today, maybe you understand my problem then :).
If you look at the diagram there should be a top hat shaped spacer on the disc side, it goes between the bearing and the fork leg.
HELLO, i HAVE A 1987 WR 240 , DO YOU HAVE ANY OVER SIZED PISTONS. THIS IS BORED AT .20 OVER AND MY NEED TO GO LARGER. i MIGHT GET BY WITH A 020 OVER. THANKS FOX82
Start a new thread ol mate, you will get better results:);)
