Shaun Webb
Hi all,
I'm in the middle of rebuilding a 1997 te 410 leftkicker, drive chain on the right hand side of the bike. Before I insert new bearings in the cases I wanted to make sure that what I've seen is right.
Basically when the clutch is pulled the clutch arm moves, partially rotating a shaft (useless with correct terms) which in turn pushes the clutch rod and separates at the and steel clutch plates.
The shaft which the clutch arm joins, is it meant to rotate a full 360 degree OR should it only be able to move a little.
Thanks everyone
Webber
Thanks everyone
Webber
