HELP needed. TE450 Cyl head removal with lower engine mounted
skyrubber
Hi,
I have been doing engine repair work.
I thought I heard that cylinder head is removable with engine still mounted to frame.
Today, during the job, I tried to remove the head from the lower engine.
But it was impossible owing to the frame tube.
Is here anyone how to do it?
Or is it impossible to do so?
Please help me. I keep my bike's engine opened. TT
Thank you.
not sure about 450 but i just had head off TXC 250 in bike and it came off fairly easy. is the front cam chain guide in the way if so you just have to undo an allan headed bolt on lhs of head. good luck .
No. You cannot, just not enough room on the 450/510. The cylinder is much too tall. You will have to pull the motor to remove the head - it is not very difficult to do - just a bit more work.
You can remove the 250/310 head as the cylinder is shorter.
^+1....someone asked this on Supermotojunkie a few weeks back and it was related that the cylinder studs are just too long on the 450/510 to get the jug off while still on the frame....
