help with husky te 250 2008 TDC marks?
HuskyGT
I'm reassembling my engine. Prior to dissassembly, I put my own reference marks on the fly wheel. Now I'm having trouble aligning the cam timing marks and I'm wondering if my engine somehow turned a little bit and I didn't catch it before I made my reference mark.
Anyway, the service manual is unhelpful in this regard and so I'm wondering if anybody knows if the bottom end on a 250 or 310 has a factory TDC mark before I make a degree wheel out of a paper plate and get out a dial indicator to confirm TDC so I can set my cam timing correctly.
As far as I know, negative on the bottom end TDC mark ... Everyone I have read about, manually sets the TDC via the plug hole and then the cams ... Maybe someone else will reply with more useful info ...
Yah, it's long distance but you could call George at Uptite. 1-714-540-2958 That's all the help I have as I have not been that deep into my motors.
hoooray but dont worry i did that all is fine but my fuel pump is bad! i have changed the gas filter, but the same problem is not sending good presure
