help with speedometer
HuskyGT
hello guys
i have a trouble in my husky te 250 my spedometer not show the speed ill go in mi bike just show the number 0
its a TE 250 2008 i have a speedometer from one 2009 and the wire harness of a 2009
what i can check
thanks
Check to see if the magnet on the rotor is missing. I had one fall out of it's little housing recently on my '11 TE310. The housing is held in the rotor, near a rotor bolt, with a circlip. Very easy to replace and the part is about $6-7.
do you want to say these magnet
pic
That looks like the sensor cable. Once per rotation it should line up with a magnet that is in a hole drilled in the brake rotor. It is glued into a housing, which is inserted into that hole. The problem I had was the magnet fell out of the housing. So the sensor wouldn't work anymore and my speed read 0. The odometer also didn't advance.
The part I'm talking about would insert into a hole represented by the red dot in this diagram from the parts manual:
I can get a picture of it on my bike later if need be.
ok i have checked the disc rotor and there is no iman and no hole for the iman maybe the disc is not the original, is there some part what i can buy to adapt?
stand in front of the bike and get the front wheel off the ground by using a stand or whatever you prefer.
note where the sensor cable is screwed into the fork and slowly rotate the wheel.
While doing this, look at the rotor and try to locate where the magnet would be. It should be obvious after a couple rotations if you are watching where the sensor cable is screwed in.
Once you've located the magnet's location, spin the wheel so you can inspect the magnet and determine it's existance and condition.
If it's not stock, I can't help you, because who knows what was done.
sure i have did that you say, but there is no magneto no hole to magneto, but i think, i can do the hole and buy the magneto with the circlip at halls cycle.
easy no?
no point in buying the magnet if there's no hole for it...
You need to figure out where the magnet WAS and since it seems your bike is not stock, I cannot help you.
Here's a photo of my '11 te310's rotor. You can see the rotor bolt and the magnet, which is in the center of it's holder (it comes as a single part).
If your bike doesn't have a spot for a magnet, then most likely a rotor mounting bolt with a magnet was used. A different rotor was used in 2008 or so and prior than what is shown in the picture above. But the concept is the same...
The wheel spins and a magnet passes by the sensor once per rotation.
You can find this magnet in the parts manual for your bike. It's the same part as used in my bike: 800099775
It goes in a slightly different location, though, as shown here:
The magnet is part #15 on this diagram. Note that my bike uses a wave rotor and yours uses a more traditional design. You might need the circlip (#13 on the diagram) as well.
Good luck!
thank you for your help!
i have buyed a magnet from halls and i drill a hole of the magnet diameter, and i put, when i try the speedometer mark me speed and millage, sooo happy
thank you for your help mate i have solved this problem
regards
Hello Guys,
I am an AUSTRIAN Husky driver (just bought a TE 310 2010) and i need help!
My speedometer does not show the speed (only a zero), therfore i seachered for solutions in this forum. I read this thread now and found out that the senor is very dirty. I cleanded it but no change. So i followed the wire and discovered a cut (insulated) near to the handlebar. Where is the speed sensor connected to? Behind the light? I guess there is no plug for it? Does anybody have a picture?
The former owner disconnected all electrical devices because he used the bike only beside the streets..
(He did the 2013 "Erzberg Redd Bull Hare Scramble" but fortunately not with the husky:))
Please forgive my bad englisch...
Greetings from Austria!
Hi
I taked some pictures today.
On the first you see the two black wires coming from the speed sensor.
According to the cuircit diagramm are the two black wires directly connected to the speedometer, but on the speedometer there is only one black.
On the other hand there are two cutted wires behind the light cover ( a black and a blue one - see picture two).
There aro no more unused plugs behind the light cover. Should i connect this 4 wires?
Please help!!
regards
eurojet, if you don't already have it, you should download the 2010 owner's manual. It has a good wiring diagram that shows all the colours of the wires, and their connections.
It looks like your bike should have a blue and a black wire to the speedometer/display, but the wire you're showing looks like sky-blue, which is probably related to the turn signal indicator.
In the 2009 TE310, the wires from the sensor to the display were both black, but the 2010 diagram (from here: http://www.husqvarnamotorcycles.com.../Manual/manual_2010_te_tc_txc_310-450-510.pdf ) I'm looking at shows blue and black.
Where do the blue and black wires go, if you follow them?
Just write "not fast enough" on a piece of tape and stick it over the display.
You are a joker aren`t you?:applause:
Thanks a lot, i have the europe version with a different diagram (with two black wires up to speedometer - i guess older version, not 2010 as you mentioned).
The black one goes to speedometer plug and the blue one goes to a single blue colored loom.
So i think if have only to connect this, but the question i have are the two black interchangeable or not? (on curcuit diagramm there are PIN 1: blue/black, PIN 2: black/black)
In case there is no plug, im not quit shure which is PIN 1 or PIN 2.
Thanks!
eurojet
FYI
I connected the described wires and it works! I guess its regardless of which connection (in case of black - black wires).
Unfortunatly i bought a new sensor which i can`t give back. So i have a spare part....
hello guys
what i can check
thanks
hello guys
what i can check
thanks
My magnet had fallen out of the circlipped holder (2006 TE250, but it looks like the magnet/holder is the same on later models). I just measured the holder to find out the size of the magnet I need (6mm X 3mm hockey-puck style). I ordered 20 of them from China Inc. on ebay. Here's the link, if you want 20 of them. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItemVersion&item=170855582796&view=all&tid=1347646870007 I epoxied it into the holder, and voiola! Speedo! Hand them out at Husky rides! Stick riding pictures on your refrigerator! Amaze your friends!
Im running a wrap 9 wheels super moto conversion, the sensor is there but the speedometer is no longer working? any ideas?
