1lunger
I was never told that the 08+ models have a different oil pump/system. I was given the HF 154 oil filter and assumed it was right. The 2008 + bikes should use the newer HF 563 filter. I don't know if this is common knowledge, but I didn't know so heads up to all the 08+ owners. The 563 filter is a bit different than the 154. The 563 has a different amount of fins, better seal and most important, it has a different oil flow bypass system that's made to work with the 08+ redesigned oil pump/system. If you have been using the 154 on your 08+ bike don't worry it's ok. I would however look into getting some HF563 for the future oil changes. If anyone can explain this better, please do. Thanks and I hope this helps.
Do you think it's really OK to leave it in there for 1K? I'm at 2K now and this is the 4th oil change.
.) That one was to check for more debris and just to err on the side of caution. The last one (so it turns out it's been 3 changes) was at 2064 so a little over 1400. I think 1500 is really it, for my comfort level, as I also use the sight glass and it was looking pretty dark/murky...and I do tend to wail on it pretty routinely (not abusively, of course, but certainly enthusiastically.) Planning a long ride this weekend but it sounds as though it's fine. I'll order some of the 563's tomorrow and install next week.
