Hi guys I'm new here and am wondering if any of you have had the same problem I'm having.
Nick Stewart
About two weeks ago I was riding my 2011 txc 511 on some trails and after about 25 minutes of riding my bike stopped going. The engine was running but the bike would not go anywhere. I could literally hit the rev limiter and the bike wouldn't move. So I turned off the bike and waited about 10-15 minutes and the bike rode like normal until it hit another 25 minutes of running time. So basically I ride 25 minutes and then it loses power. Then I wait 10-15 minutes and ride for another 25 minutes then repeat. Has anybody hear or had this problem? I'd really appreciate some responses on my issue!
Does it seem like it is still making power if you can get it to redline or is it doing some weird popping and stuff? I wonder if your clutch is heating up and slipping like crazy
Torque limiter? How much oil do you run in the bike?
What this guy is describing sounds about impossible on a clutch-driven-only bike unless blue smoke is rolling from the clutch and the area is stunk up with the smell of burning clutch fibers ... This new fangled limiter does what on these 449 bikes?
Can only be clutch. Pull it down, clean it, check the springs are ok and do an oil change. I would not be surprised if the plates are stuffed.
Change the oil lately? I've heard of some wet clutches succumbing to extreme slippage with oils that they didn't agree with.
Hey bud, check the clutch master cyl fluid level....if it is too high it can cause the clutch to slip or stay disengaged when hot.
