hot start problems with 12 te 310
richard kersten
Went out riding last weekend and bike started fine , got into ride and noticed bike was get harder to start with the e start , after last stop bike wouldn't turn over so I had to kick start it and it started fine , got home and bought a new battery hooked it up started fine , went to go out riding this morning and bike fired up good , got 6 miles into ride and stalled in the sand , hit the e start and no go , kick started fine , loaded bike up got home and it fired up with e start but once it's warmed up nothing , any advice would be great , it is at the dealer now cause I got the 5 yr warranty but still wanna know what u guys think it is. Thanks
Mine had exactly the same symptoms, it turned out to be a bad ring gear. Pop your stator cover, and if your magnet is covered in metal shavings take a look at your ring gear. On the upside parts were covered under warranty.
Still at the dealer , they are replacing the starter motor , these guys are incompetent, tried to tell me these bikes starters don't usually work when motor is hot , it's under warranty that's the only reason it's there , the only reason they are replacing the starter motor is cause I told them to.
