How do I clean these Titanium Valves?
R_Little
I got the head apart and I'm going to replace the one slightly bent valve.
As you can imagine, there is a little carbon on the valves and port area.
The seats look good but I guess could use a scrubbing with a toothbrush or something soft.
I've heard you cannot lap TI valves? Are these x-lite valves Ti or Ti coated?
What is the best way to clean them without damage? Both the stem and valve face?
What about the ports (exhaust) and seats?
I want clean but I don't want damaged valves and seats in order to to get it.
Thanks!
Intake deposits came off with my fingernail after I soaked them in Techtron.
The exhaust valves have the deposits cooked on so they are proving a bit harder.
I have not tried the scotchbrite yet.
I found a lot came off the exhaust port with just a paper towel, but I will need maybe techtron there as well
Clean them like you would clean any other valve. Wire wheel will work.
You can, BTW, lap Ti valves, especially if they're going on hard seats. I build cylinder heads. I've always done it, and every race engine builder I know does
They seal good as is.
I'm just going to clean the seats with a toothbrush and some simple green and replace the bent valve and if they still seal good I'm going to leave it at that.
