dfeckel
I've searched, and no results.
2014 TXC 310 R
Trying to remove the starter motor, and I'm unable to sneak it past the coil, which is attached under the throttle body.
For the life of me, I CANNOT get the coil nor the connector removed from the bracket. I can't even get the connector apart! What's the trick?
I feel if I can get the electrical connector off the bracket, then I can slide the coil's rubber mount off. But I can't even get the connector apart, much less slide the female part of the connector off the bracket. Help!
2014 TXC 310 R
