Huqvarna lighting help
Sph123
HI, flipped my 08 TE510 and busted the rear fender, lights and then some. I just put on a new fender, lights and blinkers. I get everything to work except the rear running light. it works if I touch it to the battery but not when I hook it up. wire colors are Blue, Green and Yellow on the new light and match whats on the bike, yellow is ground. I forgot which is which on the other two. Now to the question, instead of tearing the bike completely down and undoing all the wiring harness, can I jump the parking/running light to any other place and make it work? Thanks,
Figured it out, Yellow on yellow, then green on blue and blue on green. plus the brake light doesn't work unless the bike is running which messed with my head a bit. haha.
Thats right, the only light that turns on with the bike off, is the little light on the headlight.
