Husky bolt kit?
Don Joy
I've lost a couple bolts of my bike and am looking for a bolt kit. Which kit would be best for me? I've lost 3 bolts for my plastic, and a exhaust shield bolt.
I just went down to my local shop and bought a bolt kit for a Japanese bike. They are all metric. I've never seen a HUSKY specific bolt kit on the shelf (not to say they don't exist). I steered away from the KTM, since they are Torx style bolts heads.
Wow, that place is pretty cool Freaky! Especially if doing a one-off show bike or something, but dang, they are expensive!!!
They are expensive for titanium as pictured above on my TL1000R, £120 that lot cost, but very well made.
Same here. I just bought the Trackside brand for Japanese bikes http://www.cyclegear.com/eng/product/Japanese_Sport_Bike_and_ATV_Bolt_Set/web1007466
They also make a European kit, but I'm not sure what the difference is.
http://www.cyclegear.com/eng/product/European_Sport_Bike_and_ATV_Bolt_Set/web1007447
Thanks guys, I was looking at the kits and didn't like the KTM kit because of the torx. I have a Lawson bolt bin in my garage which has all the standard hardware I need, similiar to this-http://auctionimages.s3.amazonaws.com/24382/2348/24382_2348_22X0N2IG1.jpg . it's just the plastic bolts have the flange and some have a thick shaft and small threads. I go over my bike pretty well so I'm a little surprised that I'm loosing bolts like this. I haven't locktited them but, never had to in the past. That will change now.
Some need locktite, some need anti-seize...
My rule of thumb. The ones that fall outneed locktite, all else gets antiseize!
Loctite, anti-seize, silicone. Recently I have been safety wiring certain bolts. Subframe was first, engine to frame bolts and nuts( pain in the A$$), kickstand, exhaust the frame bolts, wiring the brake pad clips together, then the bolt for the TPS coverimage.jpg made this cool guy cover for the TPS housing out of scrap aluminum
image.jpg my exhaust to frame threads stripped out so Lawson bolts were used too. A little heat shrink over the wire and you can't feel it. image.jpg also got a little anal on the exhaust springs. You can see how the frame to engine bolts were secured. A little dab of silicone on the ends of the wire keeps four letter words at bay
