Husky Club formula Silver paint sample
GaryM
This is a reference for all. Here is a couple photos of the Husky Club Paint code with fresh coats applied on frame. Used DuPont top of line base and clear over epoxy primer
Real pleased with paint color. Photos shown are before wet sanding and buffing.
Of course I have found a new real high impact Hard Clear available from Tamco
and I would have used it instead, but its high priced. Will use it next. Its expensive.
This project has two primer coats, two light and third thicker color coat, two clear coats.
Oh waiting on first rock hit !
Posted this on Picklito post of his fine restore first.
Thanks to Darin - all his painting got me started he posts under dartyppt
Ive been told the closest RAL number is RAL 9006. Im going to give it ago when I repaint my 82 430. Yours looks like a decent colour match.
Looks great, nice job. You will find with clear coat that you can go in and repair any areas, chips etc..... Without repainting entire frame. As far as my painting goes! The shop is closed . What a winter! We keep getting up to -40 below windchills and one snow storm after the next. Running out of places to plow and pile it. At least the groundhogs say: only 6 more weeks of winter ********************************************************************************!
Well it's just gorgeous, and a very good match from what you can see in a photo. Either way, with all that attention to detail, it's a pretty sure bet that you've got a better finish than original!
Out here I use a Duplicolor product in a rattle can .. the code on the cans here in OZ is DSC44..it is a Mitsubishi color.. Mercury Silver.. a coat of clear over the top.. all good..
I have Rustoleum Appliance Epoxy silver in spray can that is very close according to Ruwfo but for anything I build to keep I would rather spray with PPG Omni Epoxy.
The frame I sprayed with Rustoleum last year seems to chip easily
Cannot wait to test the Tamco product for clear on next project. Suppose to be real protective. Want to know how the diamond clear product holds up that Darin used on his
bikes in the spring.
Has anyone tried the Wurth European car wheel silver? I have some for a BMW Z3 wheel I tweaked...but I dont have a silver frame to compare it to.
