Husky CR 500 ignition timing
Martint93
Hi, does anyone out there know the ignition timing for a 85' cr 500? I'm going to run the SEM ignition..
how is the ignition timing for a 87' 430? also with SEM ignition..
thanks Martin
thanks Martin
I belive that ignition timing for the 500 is 18 degrees of crank rotaion before tdc or measured from the piston it should be 2.8mm before tdc.
Tfhe 430 should be 17 degrees or 2.2mm before tdc.
Why SEM? Those tend to run backwards sometimes. Should've gone with a Motoplat or an aftermarket Medium Shaft MZ-B ignition.
what do you mean by run backwards? that the engine fires up the wrong way? how do you make that happen?
I run my 430 at 2.05mm BTDC and it has never happend to me..
I run SEM because it was original on my 430 and it has better light than motoplat I think (70w vs 35w)
I have seen some very light flywheel equiped bikes fire up and run backwards if the timing is far enough off and you kick them very slowly but that is rare on a Husky and not really dependent on which brand of ignition you are using. It takes a perfect storm of misadjustments to make that happen.
Do some reaserch, the SEM ignitions had failures and fired backwards, it was a common problem. Happened to my father, two of his friend, and my uncle. It had nothing to do with ignition timing, it was an actual failure causing the bike to run backwards as 2 strokes can run in either direction.
Every time this happened to them the bike was running, then all of a sudden the bike would stall then back fire and the tire would lock up. So it fired backwards all of a sudden, not if you kicked it slowly or not. They would restart the bike and sometimes it would fire the correct way other times it would take a few tries to get it back in the right direction. My father is also a certified motorcycle tech who has been doing this his entire life, so the ignition timing was never off, just a simple failure in the ignition system.
The motoplat ignitions never had this issue, onle SEM.
