CR390_Kevin
OK Husky 390 experts. I have a '78 CR390 with a bad crank.
In checking the parts books I noticed 77-79 have the same numbers for complete crank assembly and (of course) sub components. The 1980 crank has a different complete assembly number apparently due to a different right side (ignition) shaft as shown in listing below.
Does anyone know if the difference in the 1980 crank means it cannot be used in the '78?
Here are the numbers from the parts books.
1977
Crank Assemb 1611599-01
Right shaft only 1610868-01
Left shaft only 1611543-01
Rod kit 1610642-01
1978
Rod kit 1610642-01
1979
Rod kit 1610642-01
1980
Crank Assemb 1611599-02 (different)
Right shaft only 1611815-01 (different)
Rod kit ? part number not listed
Are these cranks difficult to press apart? I did some japanese cranks years OK and those went fine. Maico cranks were much tougher to press apart. Where do the Huskys fall?
These cranks are not full circle either so seem more difficult to support in the press.
All comments appreciated!
Kevin
1977
Rod kit 1610642-01
1978
Rod kit 1610642-01
1979
Rod kit 1610642-01
1980
Kevin
